Le Coultre cal814: please help
Ko1892
Postby Ko1892 » Fri Jan 01, 2016 2:24 pm
Hello there,
I really like this memovox cal814, the serial 1022xxx dated 1954 which make the unsigned crowns look ok as i understood they starting singing the crown in late 50s. But i cannot see any case reference number, should it be on the case back? The cal number 814 is on the movement but doesnt say K814 or P814, i tried to match the watch with some k814 samples from Zaf's book but couldnt, the marking in the case back also has different format so i am not sure if this watch is correct and original, would really appreciate your opinion on the watch and a suggestion on the price range if possible. :D
Cheers
KO
jaeger-lecoultre-memovox-ni-omega-rolex-ni-longines-186301-MLC20320501947_062015-F.jpg
Ko1892
Re: Le Coultre cal814: please help
Postby Ko1892 » Sun Jan 03, 2016 1:00 am
More pictures
jaeger-lecoultre-memovox-ni-omega-rolex-ni-longines-824401-MLC20320501970_062015-O.jpg
Postby zafbasha » Tue Jan 05, 2016 9:14 am
Hi, no it looks OK. The case reference #s were not always stamped on the insides.
Ko1892
Postby Ko1892 » Wed Jan 06, 2016 12:09 pm
Hi Zaf, thank you for the feed back.
Do you have any suggession on the price range for the watch? Also what is case ref for this watch will it be stamp somewhere else rather than the case back?
Thank you and regards
Ko
Postby zafbasha » Mon Jan 11, 2016 10:28 am
Check the apparisal corner, there is a similar watch being discussed there. If you didn't find a ref yet on the vase back, it doesn't have one.
Ko1892
Postby Ko1892 » Mon Jan 11, 2016 12:11 pm
Hi Zaf,
Thanks for your feedback...in your opinion do you think the waYch is relumed or original? Also is it normal for the watch not to have the ref stamped?
Cheers
Ko
Postby zafbasha » Thu Jan 14, 2016 10:52 am
Hard to say on the lume without seeing it. As long as it's pleasing the the eye, it doesn't impact value.
Many LeC of that era didn't have case refs on them.
Ko1892
Postby Ko1892 » Mon Jan 25, 2016 10:25 am
Thanks for your help, i should receive the watch anytime soon :D
Postby zafbasha » Wed Mar 30, 2016 3:20 pm
I'm confused. Which messages? Private ones or posts to the forum?
Ko1892
Postby Ko1892 » Sun May 08, 2016 12:43 pm
Hi Zaf
I am confuse too...What do you mean by messages?
Cheers
Ko
Users browsing this forum: No registered users and 64 guests
