what date is this vintage Jaeger from?
swatlas
Postby swatlas » Tue Jan 17, 2017 6:36 pm
Listed as a 1955, which is important to me. Chronograph, 38mm diameter. Manufacture movement column wheel caliber 285.
Thanks, just want to be as sure as possible about the year of production. I realize it may not be so definite.
Re: what date is this vintage Jaeger from?
Postby zafbasha » Thu Jan 19, 2017 7:40 pm
Almost impossible to date chronographs to the year, but I can give an approximation on SOME models based on the case back serial number.
swatlas
Postby swatlas » Thu Jan 19, 2017 7:57 pm
Here is the case back
Postby zafbasha » Thu Jan 19, 2017 8:02 pm
I can not date it authoritatively, but 1955 is a good guess.
I only have info on the watches made completely made by Universal Geneve (for Jaeger) and this is not following that serial number scheme.
Postby zafbasha » Thu Jan 19, 2017 8:08 pm
If it's a watch you're trying to buy, I'd take a really hard look at that dial, it's likely refinished.
swatlas
Postby swatlas » Thu Jan 19, 2017 8:16 pm
Thanks so much, really appreciate it.
swatlas
Postby swatlas » Fri Jan 20, 2017 12:02 am
By the way, assuming it has been refinished, what does that do to the value? Significantly reduced?
swatlas
Postby swatlas » Sat Jan 21, 2017 10:29 am
Here is what the seller replied to my question about the dial (I would appreciate your opinion on what this means to the value of the watch):
"All parts of the watch are original. The dial is also the original dial, and it's a new coating on the dial, that means: The old lacquer
was professionaly removed and smoothly coated a new UV-protective lacquer on the original dial. This was made by the manufacturer, who produces the dials for the Swiss manufactures (VC, JLC, IWC).
The indices, hands and colorcoating were not touched."
Postby zafbasha » Mon Jan 23, 2017 9:45 am
Sounds like the seller is trying to tell you it's refinished in a roundabout way.
swatlas
Postby swatlas » Mon Jan 23, 2017 9:48 am
Yes, but what does that mean to me in terms of the value of the watch? Assuming a watch has been refinished, does that reduce the value and if so, is that reduction significant? Thanks.
Users browsing this forum: No registered users and 48 guests
