1930's Reverso
Osrever
1930's Reverso
Postby Osrever » Fri Jul 17, 2015 9:19 am
After years of searching, I've finally managed to find a nice men's 1930's Reverso. However I'm not too sure about the originality of the dial, I suspect it is a repaint from a few decades ago. The crown also isn't original, but I don't think it will be too hard to find a better match for it.
The case looks good to me, matching serial numbers on the back and inside the case, 14 7xx.
The movement is signed LeCoultre (so I guess that should correspond with a LeCoultre dial, shouldn't it?), no caliber reference, it's a 15 jewels centre seconds movement, with serial number 45 1xx
Pictures: http://imgur.com/a/Jha7U
I blurred out the last part of the serial numbers in the pictures.
Could you shed some light on this?
Thank you!
Re: 1930's Reverso
Postby zafbasha » Fri Jul 17, 2015 10:41 am
You can have a LeCoultre movement on a Jaeger-LeCoultre dial in some circa 1937 Reverso, but generally speaking, yes, I'd expect a LeCoultre dial.
Yours is redone anyway, and it doesn't seem to be that great a job, so no hard in re-doing it properly again.
Zaf
Osrever
Re: 1930's Reverso
Postby Osrever » Sat Jul 18, 2015 6:35 am
Thank you for your quick reply. Does everything else look fine? What year would you date it to? (I thought 1936).
I'm definitely planning on getting the dial done again, any recommendations as to where I could/should do it? Any ideas what the dial should look like? LeCoultre or Jaeger-LeCoultre signed?
Based on those hands, could this be the correct matching original dial?
http://www.chronomania.net/forum/mix_en ... aorL_ntmko
And this is definitely a long shot, but do you think it's possible to source a matching NOS dial for this one?
Re: 1930's Reverso
Postby zafbasha » Mon Jul 20, 2015 1:07 pm
I'd say 1935, so it probably had a LeCoultre dial. The model you show as an example is an OK pattern to follow, LeCoultre would be most authentic in my opinion.
Users browsing this forum: No registered users and 17 guests
